USB VISA WRITE 4 bytes to FPGA
hi,
i am new to lab view.
my requirement is:
i have to sent some(5)  bytes of data to FPGA.
using VISA WRITE function.
i have tried using some VI's available as example.
but showing some errors.
please review my code(attached) and suggest to overcome the issue.
Message 1 of 16
(3,867 Views)
attachmets
Message 2 of 16
(3,860 Views)
Hi Rajesh,
to send data to your FPGA you should use either access FPGA control directly or use a FIFO.
Both ways are explained in the example projects coming with LabVIEW RT and FPGA module!
(I guess you talk about a LabVIEW project involving a NI FPGA target, don't you?)
Message 3 of 16
(3,857 Views)
no its NOT NI FPGA.
its xilinx FPGA . it has USB port. so i am using VISA.
I am accessing using NI VISA.
Message 4 of 16
(3,833 Views)
Hi Rajesh,
sending 5 bytes is quite easy:
Message 5 of 16
(3,824 Views)
i am not able to find the < array of U8> pallets.
i got all except < array of U8>
Message 6 of 16
(3,817 Views)
Hi Rajesh,
this is just a numeric array control labelled "array of U8" to make the datatype of that array clearly visible…
(Ofcourse that array needs to contains atleast 5 elements to be able to send 5 bytes. Btw. why did you change the subject line of your messages from "5" to "4"?)
Message 7 of 16
(3,812 Views)
Is it the same pallet which you mentioned ?
please confirm ?
Message 8 of 16
(3,808 Views)
typing mistake : 4 to 5
Message 9 of 16
(3,806 Views)
Hi Rajesh,
I labelled that array as "array of U8", but you created an "array of I32" instead.
I wonder why you did that…
Message 10 of 16
(3,798 Views)
