USB camera using videocapx and activex
Hello
I'm trying to implement a USB mini camera in LabView using a third party activeX control from the software VideoCapX. In attachment you'll see the program in two lowest windows(I found this program on the web). Don't understad why I get error (97). I link the activex container to the videocapx.ocx file under VideoCapX folder on computer. The two top windows is just showing that the property node doesn't change to a activex component when I wire the activeX container to the automation refnum. I also see that there is no properties in the property nodes in both the block diagrams. It is grayed out and written "No properties" when i click it.
Can anyone out from this information figure out the problem? I would appreciate alot!
Message 1 of 1
(3,888 Views)
