USB communication
Is it possible to read and write a text file using a regular usb flash drive in labview? If so, please suggest the ways to accomplish this.
Message 1 of 13
(5,145 Views)
Accepted by topic author Validus_babu
Can you be more specific as to what you mean? A USB flash drive looks, at least on my machines, like pretty much any other R/W drive space, so reading and writing to it isn't any different (other than possible considerations of max R/W cycles a flash drive has in its lifetime, or possibly R/W speed compared to a fast hard drive). What difficulty are you having?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 13
(5,143 Views)
Thanks for the reply.I completely forgot I can use USB flash drive as a regular drive to read and write files in labview.
suresh
Message 3 of 13
(5,137 Views)
Please let me know,
How can  I use USB flash drive as a regular drive to read and write files in labview.
please share it.
Message 4 of 13
(4,754 Views)
Hi I12,
just plug the USB drive into a free USB port of your computer…
Message 5 of 13
(4,744 Views)
@l12ec937 wrote:
Please let me know,
please share it.
It is exactly just like writing to your hard drive.  You just have to make sure your path is going to the correct drive.
Message 6 of 13
(4,741 Views)
Hi erdW,
I 've tried for that in labview, but it does n,t detects .
here the usb port is in working condition, as well I'm biggener ( labview).
So, please suggest peace of code for the same above.
Thank you.
Message 7 of 13
(4,716 Views)
Hi I12,
I 've tried for that in labview, but it does n,t detects . here the usb port is in working condition
Does Windows detect the USB drive? Does it get a drive name (like E: or similar)?
Can you show a screenshot of the standard WindowsExplorer showing all drives connected to your computer?
Message 8 of 13
(4,714 Views)
@l12ec937 wrote:
Hi erdW,
LabVIEW does not need to detect.  It just needs Windows to create a path to the drive (D:, E:, G:, etc.).  Then you just use the standard file IO.
Message 9 of 13
(4,705 Views)
Like serial communication data transmission, how can I read/write a txt file within the usb flash drive, when ever I want.Please guide me to read/write a txt file within the usb flash drive
Message 10 of 13
(4,690 Views)
