USB drive disconnect
Hi Thierry
I have been on a holiday myself.
In a few minutes I will try to install the program on a different computer and run it again. I will let you know what the result is.
Thanks for the update
Greets
Vincent
Message 41 of 49
(1,606 Views)
Ok, I'm looking forward to the results!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 42 of 49
(1,590 Views)
Hi Thierry
I run the program on 2 more computers. One gave the same problem but the other one was running fine!!!!!!!
Looks like the problem is computer related. We maybe did not find the real problem but we found a solution!!!!
Thanks for all the help and all the effort
Really appreciate it.
Greets
Vincent
Message 43 of 49
(1,577 Views)
Hello Vincent,
Can you provide information on how both systems differ from eachother?
Kind Regards,
Message 44 of 49
(1,568 Views)
Hi Thierry
Sorry for the late replay
Both computers run on Windows XP
One is a dell(the one that is working) and the other one I don't really know. I am in Mexico for the moment.
On the Dell is Labview 2012 installed but it works also in 2011 on the other one is only 2011 installed.
If you tell me what to look for I will look it up but my PC knowledge is not retching so far.
Greets
Vincent
Message 45 of 49
(1,554 Views)
Sorry
I have replayed on the wrong massage in this topic.
Message 46 of 49
(1,554 Views)
Hello Vincent,
I just returned from my vacation, so I'm directly going to jump into this issue.
Do you know if you're using/running the code in LV2012 or LV2011 on the "working pc"?
To compare both side we would also need a MAX report of both pc's.
This allows us to see which software is installed an could also allow us to eliminate some possible causes.
You can do this by following these steps (for both pc's):
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Also the issue could be linked to the OS version or to certain configurations in your OS.
Kind Regards,
Message 47 of 49
(1,541 Views)
Hi Thierry
Sorry for the late replay.
After the test you told me to do somebody of the it department told me to check the bios. He made an update of the bios and the problem is solved.
I like to thank you for all the effort and all the help!!!!!!
Greets
Vincent
Message 48 of 49
(1,511 Views)
Thanks for letting us know!
Kind Regards,
Message 49 of 49
(1,499 Views)
