USB driver for Keithley 2260B-250-9
I am on Windows 8.1 and I have LabVIEW 2020 SP1 installed in my PC but when I try to interface Keithley 2260B-250-9 with LabVIEW, I am unable to find and update the specific USB driver for the same. Help me resolve the mentioned issue.
(1,296 Views)
Hi Mahmudul,
@MahmudulHasan123 wrote:
when I try to interface Keithley 2260B-250-9 … I am unable to find and update the specific USB driver for the same.
Isn't this a problem you need to discuss with Keithley?
They need to provide the "USB driver" for their device!
(1,270 Views)
Try to go to Google and enter "Keithley 2260"!
The first non-sponsored link is the below page. The sponsored links are also from Tektronix-Keithley but less specific to your device.
https://www.tek.com/de/products/keithley/dc-power-supplies/2260b-series and then from there go to the Downloads section. I would suppose that you need to go with the Keithley I/O Layer version C10 driver.
Rolf Kalbermatter  My Blog
(1,255 Views)
While not technically helping with your question as asked, I would VERY strongly recommend using the Ethernet port on that device instead of USB.  I have found that once you get over the initial hurdle of a slightly harder setup, the Ethernet connection is 10 times more reliable than the USB connection is.
It would also have the side benefit of not needing a driver at all...
(1,205 Views)
