USB-ethernet under linux rt
Does anyone have experience with usb to ethernet dongles on at linux RT target?
Would it show up in MAX like other ethernet ports?
Message 1 of 15
(6,020 Views)
Have you checked out these resources?
https://decibel.ni.com/content/docs/DOC-37389
http://digital.ni.com/public.nsf/allkb/94A534CA79FF8A7E86257C670068ED2B
Rolf Kalbermatter  My Blog
Message 2 of 15
(6,009 Views)
yes, but I still having issues.
the adapter has a ASIX AX88772 chipset which be supported, but running the dmesg cmd gives:
usb 1-1: new high-speed USB device number 3 using xhci_hcd
Message 3 of 15
(5,955 Views)
It should appear with an IP of 172.22.11.2
What RIO are you using?
What version of the NI-RIO driver do you have installed?
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 4 of 15
(5,941 Views)
I am using a CVS1459rt with NI-RIO 14.0.1
Message 5 of 15
(5,914 Views)
Does the "ip address show" command in SSH show the USB Ethernet adapter as an Ethernet interface?
Does max see the additional interface?
Message 6 of 15
(5,881 Views)
I dont see it in MAX, and I can try the SSH command tomorrow.
I don't see the Asix driver when I do the lsmod command
Message 7 of 15
(5,878 Views)
Sorry I mistyped the command, it's "ip addr show"
It's definitely not a good sign if lsmod doesn't show it 😕
Can you try any other adapters?
Message 8 of 15
(5,874 Views)
I ordered a bunch more (8 different) that will arrive tomorrow - hopefully I will have more luck with one of those
Message 9 of 15
(5,871 Views)
For reasons unknown to me, the x64 kernel used by the cRIO 903x and CVS 1459RT do not have USB Ethernet dongle support enabled, unlike the one used on ARM targets like the cRIO 9068 and myRIO.
Message 10 of 15
(5,853 Views)
