USB on LV
I have read the doc about "using VISA 3.0 to control your USB device"  and other relevant doc.
Second, i have build a device myself with the controller IC USBN9603 but i don't know how to let the detect the device so that i can setup the driver, i know that D+ and D- set to be high can let the windows to detect an attachment of a device so do there anything i have to do before the driver can be setup.how to make a device hot pluggable??it is my own device.
i know my question is asking about something on USB but if this part can't be done, LV interface can't be done then.
can anyone help?
(2,705 Views)
I may be over my head but isn't that stuff in the firmware you write and load on your USB device? A couple of co-workers developed some USB instruments with the Cypress AN2131 and the development kit included a lot of example C code. You should probably check with National Semiconductor.
(2,682 Views)
