02-06-2007 01:21 PM
02-06-2007 02:53 PM
02-16-2007 08:35 AM
Thanks for the reply.
I'm using the parallel read write in lab examples.
The adaport I got showed up as printer support in windows device manager.
I believe I need to find an adaptor that has data paths for an eight bit word.
Once I find this and it shows up in windows device manager and automation explorer.
I should be able to select it as a visa resource.
05:35 PM
- last edited on
04-11-2024
04:03 PM
by
Content Cleaner
For you to use it in VISA, it needs to show up in Measurement and Automation Explorer (MAX) as a VISA resource. What version of VISA are you using?
Do you need to be communicating with a printer port? Since you're sending digital data, you could use a digital board to send this information. You could easily use a USB digital board like this one.
Meghan
