USB to RS-485 converter is not detected in PC
Hi, I am using NI USB to RS-485 converter to communicate to a device which is having RS-485 communication.
It is not detected by my PC. I have checked for the VISA drivers in my PC those are already installed. I have uninstalled entire LabVIEW and device drivers and reinstalled still the problem persists. Please help me in resolving this issue.
Thank you in advance.
(7,361 Views)
This comes down strictly to the drivers of your converter.  If it is not detected in the PC, i.e. it does not show up in Device Manager, then there is nothing from a VISA or LabVIEW side of things that is going to help.  Maybe it's not a driver issue but defective hardware.
Contact the manufacturer of the converter.
(7,340 Views)
I have checked with other PCs and is getting detected.
(7,286 Views)
So it must be something wrong with the way the driver is functioning on that PC.  Or something is wrong with that USB port.
(7,280 Views)
Accepted by topic author Karumanchi
I found it, NI-Serial Driver was missing. I was checking for only VISA drivers before. I installed NI-Serial and it is working now.
Thank you guys.
(7,276 Views)
