USB?
How to write to the USB port?
Richard Pettersen
Message 1 of 18
(6,616 Views)
Normally USB device requires corresponding kernel mode
device driver (WDM). App programs need to access via
File I/O. Normally it is done by a DLL. So you need
prepare both device driver and DLL. Then the LV app
can access the DLL via Call Library functionality.
Rai
Message 2 of 18
(6,609 Views)
sorry, this was my question: "How to write to the USB port"
I need a USB-device-driver for Windows (Labview / Labwindows)
Message 3 of 18
(6,611 Views)
Is there anybody know the answer?
Is it use NI-VISA to communication with usb device?
Message 4 of 18
(6,019 Views)
Message 5 of 18
(6,006 Views)
This link is one that actually pertains to USB and VISA. You would only use this procedure though if you had the USB RAW information from the vendor or you are creating your own USB device. This is often difficult to get. Typically, a vendor will provide a dll that you can use with the Call Library Function Node. What is the device?
Message 6 of 18
(5,991 Views)
Yeah Dennis,
I got the wrong link... that was for PXI/PCI
Thanks for the correction.
_Deepu
Message 7 of 18
(5,969 Views)
I want to access the USB port through LabVIEW.
What are procedure to follow access the USB?
Regards
Surendar
Message 8 of 18
(5,737 Views)
It all depends on the USB device that is connected. You can look at the link I provided for USBTMC devices and devices for which you have no driver from the vendor.
Message 9 of 18
(5,721 Views)
Hai
The USB connection working only NI USB or any other usb. Because i alreay installed my usb driver,But i can't identified vendor ID and manafacturing ID?
Regards
surendar
Message 10 of 18
(5,702 Views)
