USB4 to PCIe adapter
Hi All,
I started to use NI PCIe card very seldom and plan to upgrade my desktop.
I found that there are USB4 to PCIe adapters on the market, for example, DFRobot LattePanda ASM2464PD Thunderbolt 4 Graphics Card Expansion Dock Module (https://wiki.dfrobot.com/dfr1168/#tech_specs).
Did anyone try to use NI PCIe card with laptop and such adapter?
Thanks, Andrey.
(786 Views)
I believe you need to use a Thunderbolt connection. I do not know if USB4 is the same as thunderbolt. I have used external PCI cards in an TB enclosure; it was a frame grabber for a camera. They work fine once configured correctly.
(762 Views)
NI outright doesn't warrant the functionality of their cards with third-party extenders or protocol converters.
For any bus, PCIe or Thunderbolt3, NI recommends using only what comes with the motherboard, not any external card.
Santhosh
Soliton Technologies
(726 Views)
Hi
Using PCI related expanders/extenders has been discussed over the years.
The following is a typical discussion :
https://forums.ni.com/t5/Digital-I-O/PCI-6515-connection-to-laptop/td-p/4312158
Regards
(710 Views)
Hi again
Not exactly answering the topic, I will mention something that worked in the past.
I used this box in the past ( 2016+ )  :
Connected to one of the high performance Lenovo Thinkpad range P50, P51, P70, P71.
This worked both for PCI boards as well as ( single lane ) PCIe boards.
The mentioned laptops were the last and best ExpressCard supporting laptops. See this :
https://egpu.io/expresscard-2-0-egpu-interface-pros-cons-candidate-notebook-list/
Today there are several boxes like the shown from other suppliers with varying features.
Some with Thunderbolt instead of ExpressCard. I don't know if they work.
Regards
(557 Views)
