USB6225 Error code -50808
Getting this Error while reading boolean. The error is at Boolean 1 line 1point DAQmx Read.
Error Code: -50808
Error:
USB transfer failed due to the USB host controller transaction error output.  Cause may be a fault in the USB host controller of the system or a faulty cable or USB-APPLIANCE.
What could be the reason and How can we solve this..
This is coming while running the test intermittently.
Thanks in advance
Amit
(3,694 Views)
Found this older thread by searching for error -50808. Resetting the device gave error 50405, which led to this post:
http://forums.ni.com/t5/Multifunction-DAQ/6009-USB-DAQmx-Read-Error-50405/m-p/1328551?requireLogin=F...
After adding a powered hub, error 50808 has not been seen (so far).
(3,354 Views)
