USB6356 to control PGAs via SPI
I need to control two PGAs via SPI protocol with my USB 6356. I have attached my code for this, my problem is that the PGA does not seem to be changing gain or doing anything at all. I am wondering if it has anything to do with the way I am sending the signal from the 6356 in Labview? Please help!
(2,526 Views)
Hi mc11
There are some missing VIs... With no changing in the gain, do you mean that the SPI waveform signal is not changing?
(2,498 Views)
