USB6501_OEM DIO Push-pull configuration
Dear Support,
I'm using an OEM 6501 USB Device from NI, at power up prior to any LabVIEW commands, digital output level is HIGH ( open drain with internal 4K7 pull-up resistor). Unfortunatly, my application needs a LOW level at default, so i have to replace Open Drain configuration by push-pull and i would like that OEM USB 6501 device starts automatically with a low level.
How to proceed to configure Push-pull mode to replace Open Drain default mode with LabVIEW commands?
Do i need to suppress all 4K7 pull up resistors on the board?
Thanks for your help.
Marc,
(106 Views)
Hi marcounet,
There's no way to change the power-on state, your device acts exactly as described in the specs: "input (high-impedance)" on startup!
Options:
  • Use other hardware, capable of setting the default power-on state.
  • Add your own (external) hardware to ensure the required power-on state. Use a DO pin of the 6501 to switch the outputs of your external hardware as required…
@marcounet wrote:
Dear Support,
This is a public forum, mainly driven by volunteers.
When you want to contact the NI support you need to start a service request within your user account…
(94 Views)
The 6501 I/O pins do not provide power-up default settings.
See Re: Can I change the power on state of the USB-6501? - NI Community
There are other models (USB-6509) that support power-up defaults.
(92 Views)
Thanks i don't know if USB6509 exist in OEM version.
Marc,
(82 Views)
