USBIO events & LABView7
I am using the USB driver USBIO with LABView 6.1. Unfortunately I can only accessed the methods and properties (like "EnumerateDevices", "OpenDevice", "GetDescriptor", "Bind", "ReadData",...) of the COM object but not the associated events (like "ReadComplete", "WriteComplete",...).
If you have LABView7 installed on your computer, can you test my COM object (dll in attachement) and let me know if its events are supported by LV7 or not ? You have to use in the classical functions palette : Communication->ActiveX->"Automation open"+"Invoke Node"+"Property Node"+"Active X Events" or something like that.
Thank you very much...
(3,117 Views)
Here is a screen shot of the activeX events 7 sees.
(3,117 Views)
Great thanks Jeremy,
It's like a dream... I upgrade to LV7 immediately !
(3,117 Views)
