USRP 2901
I'm using USRP 2901 and installed all the drivers, the problem is that usrp2901 appeared in the USRP config. utility but won't show in the LabVIEW when I open any example as Tx continuous async example.
(1,584 Views)
You can use "Device ID" as device name.
the attaced image is example for USRP B200.
(1,473 Views)
