USRP 2944-2954-2974
Hello everyone.
I would like to ask some info about the usrp's mentioned in the subject of the message .
Specifically, i woulk like to know if the aforementioned usrp's can connect to a PC that runs Gnu Radio. So that i can "run" a Gnu Radio blockdiagram that will result in the transmition from the USRP. Also, is the connection possible with the ethernet interface of the usrp? (In the specifications document regarding the ethernet interfaces, it is mentioned that "Two SFP+ input terminals used for 1G ETH or 10G ETH connectivity with the host driver." By host driver it means the computer that i use?
Thanks a lot in advance.
Message 1 of 1
(519 Views)
