02-19-2019 09:59 AM
Hello, I am new to labView and started with using USRP N210 as Receiver on LabView 2017. Now the issue is, I am unable to listen to any audio at output. I am receiving the demodulated signals at output but whenever I try to use sound VI. I couldn't get to hear any audio. I have tried using the sound VI without interfacing it with USRP and listened to audio signals but whenever I connect it with my receiver I am not getting any sound. I am attaching the VI that I made. Also, image as well.
02-20-2019 01:33 PM
Firstly, you'll probably get more/better replies posting in the USRP community rather than general LabVIEW:
https://forums.ni.com/t5/USRP-Software-Radio/bd-p/500
Also, there could be a number of things causing this issue from the soundcard on your computer to the acquisition you are creating. There are a few examples out there where people were able to listen to FM radio, I was able to find the below example:
If that example does not help you, I highly recommend creating a post in the USRP forum.
02-21-2019 12:58 PM
Thank you AirFrantz. I have reshared this post in the USRP community.
The example that you shared consisted of missing subVIs.
