USRP X310/ UBX 160 Attenuation in 10Mhz to 1.5Ghz
Hi, I'm having a 45db attenuation.
(1,670 Views)
Do you have a question?
(1,606 Views)
Yes, the question is what can be the reason. I've learnt so far that it's a problem with UBX but in depth I don't know what is the actual cause because it's more than 1 UBX daughterboards that are now having the same issue. The problem isn't with the USRP as I've used brand new UBX and it worked fine. I want to troubleshoot faulty ones at a hardware level, can you help me with it please?
(1,569 Views)
So you have a hardware problem that has nothing to do with LabVIEW. Why are you posting in the LabVIEW (software) forum?
For USRP problems you could maybe post here. I can move the thread for you.
(1,546 Views)
I'm new to community forum and I don't know what to do and from where to do? Is it moved already or I've to do something?
(1,535 Views)
Where do you want it moved? There is also this forum.
(And please use a few more sentences that make it clear what the problem is. A long litany of acronyms and just value-free statements (e.g. "I'm having a 45db attenuation", or "same issue"), without telling us if that's good or bad, does not help.). If you "learned something so far", give a link where you "learned" it. Explain the test setup and how things are connected in detail. Your problem description is currently way too terse!)
(1,520 Views)
Yes, move it there please.
My learning is practical experience. There is one Antenna of L-Band, then Bandpass Filter, 30dB LNA, Limiter and then DC Block which is finally connected to USRP. I'm now transmitting signal of -50dBm but I'm receiving it at -80dBm even though it's over the wire, I've changed the transmitter but problem persists anyhow it works fine in 1.5 to 6GHz band
(1,482 Views)
