USb_8451 I2C Communicate With TLC59116 (LED IC)
I face a problem in communicate witht the TLC59116 IC.
I have follow a the datasheet to send the signal.
However, when i capture the signal with scope, the data only show the address bit.
Anybody can help me on communicate witht the TLC59116 IC.
GUY
(3,097 Views)
Im proberly sitting with the same kind of issue. Im supposed to communicate with my TLC59711 LED driver.
So I was courios if you figured out and could help me through?
Best Regards
(2,766 Views)
