Ubuntu daqmx / miss: ni-daqmx-labview-2021-support
Hello experts,
I am trying to install the daqmx driver on Ubuntu as described here:
https://www.ni.com/de-de/support/documentation/supplemental/18/downloading-and-installing-ni-driver-...
apt-get install ni-daqmx
Unfortunately the VI's of the daqmx driver are not visible under Labview 2021SP1 after the installation.
I am of the opinion that you should also install the package:
apt-get install ni-daqmx-labview-2021-support
to make the VI's visible under Labview. But this package is not included anymore. In former times there was this package.
My question: How do I make the daqmx VI's visible under Labview?
Greetings, Jim
(1,939 Views)
No answer...
Has anyone ever gotten the daqmx driver to work under Labview?
Have a nice start of the week, Jim
(1,892 Views)
dear Jim,
checking the latest readme for the Linux drivers, this is currently expected:
https://www.ni.com/pdf/manuals/378353f.html
greetings
Jack
(1,863 Views)
We just fund this same issue with LabVIEW 2022 and DAQmx 2022 Q3 (checking to see if it was possibly Q4) installing on RHEL 8.
https://lavag.org/topic/22470-ubuntu-daqmx-miss-ni-daqmx-labview-2021-support/
The repository is missing the LabVIEW support package  ni-daqmx-labview-2022-support.  Once this is found and installed then the DAQmx VIs show up on the Functions palette.
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(1,534 Views)
