Uisng the Dual Channel Spectral Measurement block inside a while loop for averaging
I am currently using the Dual Channel Spectral Measurement block to perform analysis of a system. One of the goals is to perform the analysis several times and average the results. For that, I have placed the block inside a while loop and turned on the averaging option, but I am still confused if this is the correct approach to achieve my goal.
I would truly appreciated fi someone could provide some additional insights
(224 Views)
Start with showing your code. Words are insufficient to really tell what you are doing.
(196 Views)
Accepted by topic author JB9
This LabVIEW example does just that (put the dual-channel spectral analysis block in a loop):
<LabVIEW>\examples\Express VIs\Express VI - Dual Channel Spectral Measurement.vi
This example doesn't use Express VIs:
<LabVIEW>\examples\Signal Processing\Waveform Measurements\Frequency Analysis of a Filter Design.vi
These examples each measure the averaged frequency response for a digital filter. If you need to measure the frequency response for a physical system, acquire the reference and response signals in the loop as well.
AND as Altenbach suggests, share your code to get more directed guidance.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(168 Views)
