Ultrasonic Anemometer
Also remember that your  PCI-6024E have a total sample rate sample  rate of 200Khz. If you use 2 channels each channel will have max 100Khz sample rate
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 16
(1,352 Views)
I think you need a daqcard like this NI PCI-6143, and a analog waveform generator. The NI PCI-1643 has simultaneous sampling
Message 12 of 16
(1,350 Views)
I don't need simultaneous sampling, though. Guess I do need an external analog waveform generator to make me that 30KHz, but other than that I can still use my DAQ. Just need to figure out how to code it in LabView 😛
Message 13 of 16
(1,334 Views)
Hello Flapke,
there are DAQ boards available with a high sample rate on the analoge output (such as the NI 6251). But when we are speaking about sound generation and acquisition you may want to have a look at the dynamic signal analysis hardware. Please note that these cards are simultaneous sampled.
When your academic institute has a academic site license there is a big chance you have also access to the sound & vibration software , when installing this software a lot of examples are added to your example finder.
Martijn S
NI Netherlands
Message 14 of 16
(1,323 Views)
Right, so I got a bit further now. Made some sinus generators that work like a charm, can make pulses and measure them and use a counter to see what the travel time was. Great, except I used a software analog trigger, so the results are completely wrong.
Is there some way to sample the counter at the exact time I send out a pulse from an analog out channel, then sample it again exactly when I receive a signal on one analog in channel and again when I receive a signal on a second channel?
Again, all I have available to me is an PCI-6024E.
Message 15 of 16
(1,257 Views)
Hello Flapke,
If I understand you correct you will need to synchronize the analogue input with your analogue output. You can find a great example to do this; multifunction-synch AI-AO.vi (examples => hardware input and ouput => synchronization => Multi-Function). The example is to synchronize the analogue output with the analogue input. You need to do this the other way around.
There is also a excellent tutorial about the synchronization features from DAQmx. I hope this will help you further,
Martijn S
NI Netherlands
Message 16 of 16
(1,229 Views)
