Unable To Run The Build Application
The Labview Code Runs Fine
I'm Able To Create A .exe File
But The Problem Is When I Open The File It Shows The FileName In The TaskBar For Like About 3Seconds And Then Closes...
This Is In The Development Computer,But It Works Fine The In Other Computer Using The Run Time Application
Using Labview 2012
I Did Not Have This Kind Of Problem Earlier..
Earlier Everything Worked Fine
I'm Getting This Even For A Simple Add Two Number Type Program
(3,063 Views)
It looks like you've badly changed something in Labview settings I need more details to answer your qestion.
1. Are you running your EXE file on the same computer where you have Labview installed?
2. For the simple 1+1 example could you attach all files you've got in your build folder and project files as well?
(3,040 Views)
YUP Same Computer It Was Developed In
(3,030 Views)
Your EXE works absolutelly fine to me.
That points to the problem with your run-time engine installation.
(3,023 Views)
