Unable To pass array from Labview to Vb.net?????
hi
i have created one simple application in labview and i am able to transfer single or seperate multiple variable from Labview to Vb.net
but now i want to pass  single dimension or 2D array how i can do this (for same  Labview to Vb.net)  ???????????/
Message Edited by Viren Patel on 01-20-2006 04:49 AM
(3,033 Views)
Hi There,
you can do that straight forward:
define a public method as member of a public class in a dll project an
declare it to consume arrays:
(I'm not very familiar with VB so I take c# translation is easy)
public class ArrayConsumer
ArrayConsumer ( ) {}
void ConsumeArray ( double [] p_n1DArray )
//do something
Now refernce that class with labview and use an invoke node to call
ConsumeArray!
just put a labview 1d dbl array to parameter p_n1DArray ... done.
Use "create constant" from the input parameters context menu if you are
unsure how to build dbl arrays.
Greetings, Sebastian Dau
"Viren Patel" <x@no.email> wrote in message
news:1137755454791-313488@exchange.ni.com...
> hi
> &nbsp;
> &nbsp;
> but now i want to pass&nbsp; single dimension or 2D array how i can do
> this (for same&nbsp; Labview to Vb.net) &nbsp;???????????/
> &nbsp;Message Edited by Viren Patel on 01-20-2006 04:49 AM
(3,028 Views)
