Unable to Open a Remote Panel of an Asynchronously Running Clone VI residing in a Packed-Project-Library in a built Executable
The title suggests I am really up against some edge-case usage but anyway...
When making use of LabVIEW 2018 (64-bit) built in functionality to open Remote Panels (not remote-debugging) I appear to be unable to open a VI's front panel of a built-executable if that VI resides in a packed project library. The VI in question is an asynchronously running clone VI and I have not tested a typical top-level VI. I also have not tested if this also occurs when the application is running in the LabVIEW Development Environment. I have tested if this still works if the packed libary is debuggable or not - it happens in both cases.
I have attached my example code which consists of two projects: Main which is the "main" project and Clone-Library-Builder which is purely used to produce a packed-project-library.
The Main project can be used to build the Test-App.exe executable. When the executable is run it does the following:
  1. Opens a dialog to allow the application's webserver port to be set so it doesn't conflict with the port used by the LabVIEW Development Environment.
  2. Generates a webserver configuration file which it loads using a LV Application invoke node.
  3. Launches two clone VIs - one from the packed project library and one from a normal project library. Each VI indicates its clone name which is required when connecting to it.
With the Test-App executable running I use my LabVIEW Development Environment to do the following:
  1. Open the "Connect to Remote Panel" using Operate>>Connect to Remote Panel...
  2. Set the Server Address to "localhost"
  3. Set the port to that which I specified (also displayed on each clone VI)
  4. Set the VI Name to that specified on the clone VI
  5. Click on Connect
This functions as expected for the non-packed-project VI but if I attempt to connect to the packed-project version of the VI I encounter the following error and the LabVIEW Development Environment crashes!
I would be interested to know if anyone else has tried something similar and do they also encounter any issues?
I was considering developing an application where remote systems are running a remote-app-server which launches plugin-apps and allows for clients to easily list remote panels on a range of hosts and open them. Use of packed project libraries would just be a nice-to-have of a fictional application.
Cheers
John
Message 1 of 1
(2,084 Views)
