Unable to activate Labview in Parallels on Macbook
We have purchased Labview 8.6.1 and upon installing I am unable to activate the product.  There was no certificate of ownership provided, and the only serial number o was able to find is the part number on the lamination of the box, which is: 501510F-00  I used 501510F in an attempt to activate the product.  An error message appears stating that the serial number is invalid.
(3,014 Views)
Accepted by topic author Atro
Yeah that's not the serial number.  It will start with a letter, followed by two numbers, a letter, and 5 more numbers so some thing like this.
A11A11111
You can try to activate online on another computer by going to www.ni.com/activate
(3,007 Views)
You should contact your local NI Sales Engineer or NI directly if your serial number is missing or it got lost.
(3,000 Views)
Hello Atro,
There should've been a 9 digits alpha-numeric serial number somewhere on the box/CD/packaging. If you are still having issue actvating LabVIEW, please call in at 1-866-275-6964 and one of our applications engineer will be able to assist you.
Andy Chang
(2,965 Views)
