Unable to browse OPC Server from the selected machine / Error -2147221163 occurred at GetOPCServerList.vi
Hallo,
I just installed LabVIEW 8.2 DSC-Module and tried to configure a OPC Client Instance. I get the Error "Unable to browse OPC Server from the selected machine / Error -2147221163 occurred at GetOPCServerList.vi". I have no OPC-Server installed, but is there no Demo-Server?
Thank you
Thomas
(8,696 Views)
Check your security settings.  First, turn off the windows firewall.  Search on DCOM settings on this site.
(8,677 Views)
I don't want to connect to another machine.
I would like to connent to a Demo OPC Server on the same machine, like it was possible for example in LabVIEW 7.0.
(8,660 Views)
  1. This issue might be related to opcenum not being registered correctly. Please follow the steps explained in this document to fix this problem.
  2. As OPCdemo follows the OPC 1.0 standard it is not supported by the OPC client in LV DSC 8.x which supports OPC 2.0 and 3.0 servers. You can download an OPC 3.0 compliant demoserver from Matrikon.
I hope that helps,
Jochen Klier
National Instruments Germany
(8,653 Views)
Yes, it did help!
Thank you very much.
Thomas
(8,648 Views)
