Unable to call user defined function in math script node
I am using math script node in my VI. When I call user defined functions(.m files) in the math script node, it is not recognising the user defined functions. (.m file path is correct. )
When I call the same user defined function in blank VI, it was running good for first couple of times. Now it is giving error without any modification on the code.
Am I doing anything wrong? I am confused and looking for some guidance to solve this problem.
I am attaching the SubI  for your refernce.
Thank you in advance!
Message 1 of 1
(2,932 Views)
