Unable to deploy Shared Variables on RT target
I have an sbRIO and LV2010 SP1 running on VISTA. It's always on power but power around where I am at, comes and goes. After one month of not using it, it stopped accepting the deployment of network shared variables. I uninstalled the RIO S/W and re-installed it and that did not help. Attached are screenshots of the error and the installed software on sbRIO. I tried everything I read on this post including connecting direct to it, disabling the firewall, with no luck! I have a feeling that SVE/NVE is not running on sbRIO. How can I verify what processes are running on it? and why wouldn't start when the system is restarted?
Sam
Message 11 of 16
(1,815 Views)
A good way to see what's going on with your controller is to use the console out.
This KB talks about how to set it up and use it.
It should tell you what's running on the RIO and could help you narrow down what's going wrong.
CLD Certified
Message 12 of 16
(1,796 Views)
Voila!
Receiving Error -2147220696 when deploying shared variable library to cFP-2200:
Thanks to Zach-H for trying to help.
Don't ask me why I didn't find that link initially when I searched for that error. I guess Google DB just got updated today?! I don't believe it, I was just lucky today!
Message 13 of 16
(1,792 Views)
I am using NI cRIO 9025 module. I have conncected the chassis with few cSERIES channels for voltage and current sensing.
When I tried to configure, I am getting the following error
Access denied: This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer.
I tried to use Add/Remove option from MAX. But I am not able to update the real time software on cRIO
I am using Labview 12.0 on host computer and on target cRIO9025 - 11.0.1 version real time is installed.
Please kindly help to update the software on target module.
Ravi Kishore
Message 14 of 16
(1,429 Views)
Hi Ravi,
It appears you have posted on a forum that is a couple of years old.  To ensure better visibility from the engineers who monitor the forums, as well as helping us keep track of what kind of issues our customers are running into, we ask that you create a new thread with the particular issue you are having.  You are welcome and encouraged to link this post as a reference for the error you are receiving.
Thank you!
Nick
Message 15 of 16
(1,410 Views)
Message 16 of 16
(1,313 Views)
