Unable to deploy my RT vi code on cRIO in scan mode
I have been working on NI cRIO for past some time. Today I faced a peculier problem. I was able to make necessary changes in my RT vi and deploy it on the cRIO. Everything was working fine but somehow I started to get the message of " Unable to connect to RT Target ". I was able to ping my cRIO and connect to it initally but as soon as I started running my RT vi on it , the connection was getting broken. I was even unable to ping my cRIo.
I searched a lot on net and even tried to reinstall the software on my cRIO. THe error code was pointing toward the SVE, but I had installed the required software for network variable engine on my crio. I am attaching the screenshots of my project and the error messsages.
Please let me know how can I run my RT code again on crio .
THanks.
(2,662 Views)
I have been working on this issue and referred to earlier discussions like:
http://forums.ni.com/t5/LabVIEW/RT-cRIO-Shared-Variable-Engine-Errors/td-p/1697368
I have added a delay in my RT code (in initialization phase) and since then I have been able to solve the issue. Basically I think that SVE needs tome to work.
Please let me know if anyone has any better idea.
(2,638 Views)
