Unable to display results
Hi. I have a program that capture data results from gpib and then
display them using leds. When i run the program, 2 problems occur:
1)No results are displayed.
2)Display Front panel never pop out even though i set the VI execution
properties.
The funny thing is that when i monitor the program movement by running
it in steps, there isnt any error in the program and the results are
properly captured and displayed.
(2,370 Views)
As you mention in case 2, you can run your VI steps by steps. One
possibility is that you are scanning data too fast from your device.
That�s why you cannot see the result. My suggestion is do some
sampling. What do you mean by "Display front panel never pop out�? Is
your VI crash? Or something.
If you can post your VI, I think it is better for us. Somebody here
can help you.
(2,370 Views)
