Unable to get the coordinates of ROI correctly
Hi all,
I am trying to obtain the grayscale values of pixels from a region of interest. The way I am doing is (1) converting the whole image into grayscale values and plotting an intensity graph.  (2) drawing an unflattening pixmap of the same image then drawing rectangle on the region of interest to get the coordinates. The problem is there is an offset in the coordinates of the intensity graph and the image means I am not getting the values from the ROI. Is there a way to remove the coordinates offset ?
Thanks and Regards
Hassan
(1,342 Views)
A million things could be wrong.
Post what you have.
(1,299 Views)
Accepted by wiebe@CARYA
Dear
(1,297 Views)
