Unable to implement ratio control
You need a series of pictures and some software that allows stitching them into an animated gif. I use corel photopaint, but there are many others (do a google seach for "make animated gif").
(But please simply attach your VIs. Everybody will be able to open them in any newer LabVIEW version.)
Message 21 of 26
(1,313 Views)
OK, thanks. I know how to do this using photo software. I thought maybe there was some feature of LV capable of this that I was missing.
Message 22 of 26
(1,310 Views)
Here I am attaching the VI. I have done just the same thing but my VI is not running. Strange indeed! Smiley Sad
Message 23 of 26
(1,293 Views)
What is going on in your false case?
You start a calculation, but then don't do anything with it.  Then you proceed to output a default array which means it is empty.  That breaks all further use of your VI.
Message 24 of 26
(1,289 Views)
In addition to Ravens solution, you also should change the cluster size to 4 for "Array to cluster" (right-click...cluster size) to eliminate the 5 extra chart traces at zero.
Message 25 of 26
(1,286 Views)
here i  attached the file airfuel ratio control  system. please give details  about  implementation of it.
Message 26 of 26
(1,220 Views)
