Unable to insert cluster in to array element
Hi stephen,
I have already initialised the array in the the type def when I made it, haven't I?
No you don't. You only defined a datatype, but not the value of the datatype!
Message 11 of 32
(3,748 Views)
okay so I did this, still didn't work. Only when the index was 0 did were values updated.
Labview 14.0, Labview 12.0
CLAD
Mechanical Engineering Student
Message 12 of 32
(3,744 Views)
Hi stephen,
repeat after me: "I can only replace existing array elements!" 😄
You initialize the "task info array" with just one (1) element. This first (and only) element will get index zero (0).
And you still wonder why you only can change parameters in this single array element? Really? After all the explanations before?
Message 13 of 32
(3,741 Views)
I thought the initialise dimension input was for 1D, 2D, 3D etc. not the amount of elements I want to initalise. Anyway that half works, as it reinitialises everytime the VI is called but I'll put that code higher up and hopefully it will work.
CLAD
Message 14 of 32
(3,734 Views)
Hi stephen,
When you are unsure about how the function works you should read the LabVIEW help for that function! 😄
Yes, as the initialization is part of this VI. Usually you only initialize once at program start…
Message 15 of 32
(3,730 Views)
I would normally check if I was unsure but to be honest its a rather misleading terminal name. Should be called number of elements or size of dimension.
thanks for your help anyway 🙂
CLAD
Message 16 of 32
(3,713 Views)
According to the help, the terminals is called (dimension size ...), so the focus is on the "size" in each dimension, i.e. exactly what you are suggesting. No action needed. ;).
The number of dimensions is given by the number of size inputs you expose by resizing the node. So for a 2D array you would expose two size terminals. Wiring numbers will now determine the size in each dimension and the product of the sizes will determine the total number of elements.
Message 17 of 32
(3,706 Views)
Misleading never the less. Maybe once you know the nuance its obvious but until then it isn't as clear as it could be.
CLAD
Message 18 of 32
(3,701 Views)
Pretty clear to me.  If it was what you were thinking, then it would be called "Number of dimensions".
Message 19 of 32
(3,699 Views)
Going by your profile you have 10 years experience. I would hope it is clear by now. For new user however things aren't as simple, as you should know if you think back a little.
CLAD
Message 20 of 32
(3,696 Views)
