Unable to install LabVIEW 2009, "Unknown Error"
I'm installing LabView 2009 on Windows 7 on my Hp and when I run the setup after I unzip it, it come up with an error and says "Unknown Error". How do I get around it to install the program as soon as possible.
Message 1 of 20
(5,496 Views)
You said unzip it.  Where did you get it from?  A download?  If so, perhaps it is a corrupted download.  Try downloading again.
Message 2 of 20
(5,486 Views)
I have tried to install it straight from the disk and also tried to download the version online to input my licence key. Niether work.
Message 3 of 20
(5,463 Views)
Message 4 of 20
(5,463 Views)
Owen-
You get the same error when you do a fresh install from the disc?  If so, is it a 32-bit version of LV 2009?  If it is a 64-bit version of LV, are you installing it on a 64-bit version of Windows?  Can you post a screenshot of your error?
Sean
Applications Engineering Specialist - Semiconductor Test
Message 5 of 20
(5,450 Views)
I get the same error from both the disk and the download. Let me post a screenshot of the error
Message 6 of 20
(5,428 Views)
Intel Core 2 Duo CPU @ 2.53GHz
4GB Memory
32-bit OS
HP 6530b Windows 7
Message 7 of 20
(5,426 Views)
This is a screenshot of the error...
Message 8 of 20
(5,425 Views)
What does it say if you click on the Details button?
Do you have admin rights to be able to install software on this PC?
Message 9 of 20
(5,418 Views)
Have you tried copying the DVD's contents to the hard drive and running the installtion from there? Have you tried to make sure your anti-virus software is off while you are doing this? Have you tried booting the machine so that no other third-party services are running?
Message 10 of 20
(5,413 Views)
