04-03-2008 09:52 AM
04-09-2008 04:20 AM
Which OS are you using?
If you are using your VI as a subVI, are you including the “3D Surface” control reference to the front panel graph?
You can also try using the actual graph node that appears when you place the graph from the "Graph" palette on the front panel instead of the property node for the CWGraph3D.
Error 97 might also be caused by a missing or incorrectly located OCX file. It is preferable to link your code to the OCX file in the system32 folder.
Thomas Baudouin
