Unable to locate LabVIEW RunTime Engine
Have you installed the correct bit version of the RTE ?
What bit version of LabVIEW are you using?
Message 11 of 14
(3,040 Views)
I installed the 64 bit RTE, if that s what you are asking.
I use the same 64 bit version...Is there a place I can double check the same ?
Message 12 of 14
(3,032 Views)
Did you use 64-bit LabVIEW or 32-bit LabVIEW?
Both can run on 64-bit Windows.
If you used 32-bit LabVIEW, then you need to install the 32-bit LabVIEW Runtime Engine.
Message 13 of 14
(3,027 Views)
Thanks for clearing the ambiguity. For some reason I thought it was a 64 bit Labview that gets installed by default. It s the other way around. The latest labview installed would be 32 bit by default unless it is for vision applications and such.( The help menu shows it).
I will need to install a 32 bit RTE in order to run my 32 bit application.
Message 14 of 14
(3,010 Views)
