Unable to locate labview run time engine (lab view 8.5)
Hello I have a problem whit the labview 8.5 installer. I have created I project with included a .vi file (a simple panel wich control a serial port, with parameters (baud rate, stop bits, ...)), then I have created an application for this file (.exe) and then the installer (I have included the labview run time engine 8.5). When I run the setup.exe  I have the following error message:
Unable to locate labview run time engine, the application require a labview run time engine 8.5 or compatible...
What I'm missing??
Maurizio
(4,300 Views)
hi,
You may not be missing anything.may be that exe file  has been corrupted.try to install that set up on other machin
Gak
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,296 Views)
are there one other reasons why it would not work.  I have asimilar problem.
I intsalled version 8 of run time engine and acrtivated software.  Now I am trying to run compiled application provided to me by third party.
When I click on application it says
Unable to locate LV run time engine
Test server requires a version 6.0 or compatible LV engine.
How do I know if the engine I installed and activated is running and is it supposed to be able to execute a program which is expectin rev 6 of the rund engine?
(4,152 Views)
It's looking for a version 6 runtime and you installed a version 8 runtime? I'll bet that if you install the correct runtime, the error will go away. The version of the runtime must match the version of LabVIEW that the exe was built with.
(4,149 Views)
