Unable to locate run-time engine
Hello all!
Sometimes we must upgrade some of our customer machines. Those machines where developed in Labview, but they only have the executable and the run-time.
Several times I have the a problem, we upgrade the Labview version on our PC's and we can not send them only the executable. We must make a new installer with the new version and install all that.
There is the possibility to create an EXE to a previous Labview run-time version?
Thanks in advance, best regards,
Paulo Carmo
(2,591 Views)
Hi Paulo,
Thank you for posting.
You are only able to create .EXE for and with the version of LabVIEW you build it. You can choose the version of run-time.
For example, if you have LV 2010 and you want to deploy your application on Windows 2000 (not compatible with LV run-time 2010), you have to create your EXE with at least LV 2009 SP1, and the run-time version will be the same as LV.
I advise you to follow this link to know the compatibility between LabVIEW (and the run-time) and Windows : here.
Romain P.
National Instruments France
(2,549 Views)
