Unable to locate the Labview Runtime engine for vi manager.
i have installed the labview version 2012 and try to connect with it the JKI VI Manager but having  a erroe as shown in image file.  Please provide necessary instruction.
(4,142 Views)
The LabVIEW RTE should be part of the installer.  But if it isn't, then go download the LabVIEW 2013 Run Time Engine.
(4,140 Views)
thanks for taking interest. As i have tried to install from the provided link but it did not worked out.
(4,138 Views)
Then I would recommend reinstalling VIPM.
(4,135 Views)
Did you try either of the suggestions mentioned in the Error message?  I've installed VIPM without the correct RTE before, and going either the NI's site to download it or to JKI's site (where they have helpful instructions -- I don't recall if they directly provide the RTE or point you to NI).  You have to not only download a file, but you need to execute it, as it is an Installer.
BS
(4,065 Views)
I think starting around 2013 VIPM was forced to make a new installer.  Previously the installer was written in LabVIEW, and as a result you needed the run-time engine installed before installing VIPM.  Now VIPM is bundled with the disk suites that NI sends out, which intend on installing software before LabVIEW is installed.  So they have a version of the installer that runs without needing LabVIEW installed yet.
You may also want to contact JKI, or their forums if you can't figure it out, we can help but JKI is more equipped to troubleshoot issues VIPM.
(4,036 Views)
Thanks this solution along with reinstalling of vi manager worked out for me. Thanks.
(4,029 Views)
