Unable to open LabVIEW 7.1 application (.exe) file in LV 2018
I am given a very old LV application file and am trying to open it in my LV 2018. When I try to open this file, I get an error message saying that I will need a LV run-time 7.1 installed to open this.
I understand that this is extremely outdated and nowhere to be found. Therefore, I was wondering if theres any workaround this?
Many thanks,
(1,404 Views)
You can find the Run Time Engine under
ftp://ftp.ni.com/support/labview/windows/runtime/7.1/
to execute your application.
But you can not open your exe file in LabVIEW Development System, no matter what version.
Edit: You will need the source code files to open them in the development system.
(1,401 Views)
