Unable to open VI from a different computer
Hello, I can't opet VI that was made on my working computer from my personal computer. Working computer has 2017 version and personal computer is 2018. Both are 32 bit versions. Below is the mentioned VI
(2,446 Views)
Accepted by topic author ljutica
Hi ljutica,
i'ts a bad, very bad, very very bad idea to use UNICODE chars (aka non-ASCII chars) in file names!
Rename the attached VI to something simple as "test1.vi" and LabVIEW will be happy to open it…
On your VI: IMHO you can simplify it a lot. Using subVIs would help here too…
(2,444 Views)
it worked 🙂 thank you
(2,436 Views)
