Unable to open session to "ASRL4::INSTR"
I have a LabVIEW application (in use for approximately 3 years) that is used to read environmental data from two transmitters.  Communication with these devices is through a Moxa serial server, which takes Ethernet data on the computer side and serial data on the instrument side.  The instruments are mapped to COM ports via the Moxa software.  I can only get one transmitter to work now.
COM4 has the yellow exclamation point symbol in NI-MAX.  If I attempt to open a test session to the device, I get the message in the subject line along with "Return status code: 0xBFFF0000  Status name: VI_ERROR_SYSTEM_ERROR  Unknown system error (miscellaneous error)."  If I try to access the device through the Moxa terminal emulator, I get a message indicating that the port is occupied by another program.  I am unable to delete the resource in MAX (this option is grayed out).  I have tried restarting my machine, thinking that this might clear the conflict, but that had no effect.
I can communicate with the Moxa servers over ethernet with no problem (e.g., I can ping both devices).  The only difference I can think of between my current configuration and the "last known good" one is that I have upgraded LabVIEW from Version 7 to 8.5.1 (and changes to other NI components associated with that).
(5,051 Views)
I've had no problems with serial devices nor heard of any with LV 8.5.  I'm actually installing 8.5.1 right now.
I would try reinstalling the device drivers for 8.5.1.  Perhaps there was some problem with the installation of NI-VISA.  I actually just had a problem when the device driver installer wanted disc 2.  It didn't find it right a way for some reason, then asked for disc 1 back in.  I did that.  Then it asked to continue, and actually skipped over a couple components because it couldn't find them on disc 1.  So I put disc 2 back in and the install picked up where it left off.  Don't know why it had a problem with disc 2 on the first attempt.  So I'm planning on trying to reinstall the drivers again once they are done.  Of course that is an hours long process.Smiley Mad
(5,048 Views)
