Unable to play .wav file in LabVIEW 2017 - Error 4810
I am building a simple project using a combination of Color Boxes and Random Number generators and trying to play a sound file simultaneously. I generate three random numbers in the "colour_wheel" sub VI and call it in "disco_lights".  The idea is to change the colors randomly. I am able to achieve this, but the wav file doesn't play. I get an error - "Error 4810 occurred at Play Sound File.vi".
I attempted the steps mentioned on the forum, added the Sound Output clear as well but it doesn't seem to work.  I also tried replacing the wav file, still it didn't work for me.
Message 1 of 21
(8,468 Views)
I am having the same problem. Have you found a solution? Mine worked prior to upgrading to 2017.
Message 2 of 21
(8,298 Views)
Hi, I have no problem with your audio file in this simple VI, I can't open your VI because is later than mine. Could you please post it in a previous version?
Message 3 of 21
(8,153 Views)
I have the same problem. It worked with 2016, but I upgraded to 2017 and now I get an error.  Was there a solution to this issue?
Message 4 of 21
(7,984 Views)
If ther was some code, we could test it and try to reproduce it
Do a save for Previous on an example (to 2016) and some of us with multiple versions can play with it to help you out
Message 5 of 21
(7,981 Views)
I'm trying to use the Play Sound File.vi that came with LabVIEW. I was using LV 2016 32-bit and now I'm using LV 2017 64-bit. I thought it might be a 2016/2017 issue, but I pulled the latest "The Play Sound File.vi" from LabVIEW 2017/vi.lib/sound2/lvsound2.llb.
For some reason I can't attach the .wav file.  Just change the wave file name in the block diagram, I don't think the problem is specific to the wave file.
Nathan
Message 6 of 21
(7,975 Views)
They changed the path from relative to absolute
C:\Users\Jeff\Downloads\Sound Error.vi (Sound Error.vi)
- The VI expected to be at "..\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\sound2\lvsound2.llb\Play Sound File.vi"
was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\sound2\lvsound2.llb\Play Sound File.vi".
Looks like either a bug or a feature update to the llb
OH NI /\//\/\/ (Waves hand)  Could you comment?
Message 7 of 21
(7,966 Views)
Sorry for my ignorance, but is there a easy fix to redirect the vi or do I need to wait for NI to comment?
Message 8 of 21
(7,962 Views)
So what's the fix then? I'm having the same error and I have LabVIEW 2016
Message 9 of 21
(7,959 Views)
Yes, ignore the missing vi and replace with Play Sound File.vi from the 2017 palette (Programming>>Graphics and sound>> Sound>>Output>> For all y'all non- quickdroppers)
Message 10 of 21
(7,954 Views)
