Unable to read dependencies of an included VI.
Hey all.
I am trying to build an executable for a project that I have been working on.
When I tell it to build I get the following error.
Unable to read dependencies of an included VI. Open all Startup/Exported/Dynamically called VIs, recompile them (Ctrl-Shift Click the run arrow), and save them to update their dependencies.
C:\Documents and Settings\du402c\Desktop\XPDR\Working Folder\XPDR_GUI_SELECT.vi
Details:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at ABAPI Dist Report Read Link Info Error.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File2.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller in Charge.
I can't for the life o fme figure out what is wrong.  Everything runs fine when I just run it, but I can't actually build it.
I have gone inot the main GUI and done the CTRL-SHIFT Run Arrow bit, and it hasn't changed anything.
Any suggestions?
Thanks.
Any suggestions?
(2,529 Views)
Ok, ignore this.
I created a new project from scratch and it worked fine.
(2,515 Views)
