Unable to read or write to txt file after executable is created
I have a vi that at start should read a txt(I gave it .cfg extension to help it stand out but it is a txt file) file and place the contents of the txt file in a string control. The last step before closing the vi is the contents of the string control is saved to the before mentioned txt file. The txt file contains a path to a specific directory. Everything works fine and the vi performs perfectly but as soon as I make an executable the txt file is not read from or written to. I included a picture of the read and write code I am using. I have sifted through the forums and tried including the .cfg file in the build as a support file but nothing I do seems to work, again the code works perfect until I make an executable. Any suggestions would be greatly appreciated.
Thank you,
Steve
(3,280 Views)
Are you getting any specific error messages?
I think the problem may arise from using the 'Current VI's Path' path. Have a look a this link in which Dennis Knutson gives a possible solution to file path problems and executables.
Hope this helps.
(3,272 Views)
There is just that little different between "Development Environment" and "Executable"
when Filepath is concern 🙂
Please see attached for your reference.
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,270 Views)
Thanks for the Help. I will implement the example code. This problem drove me crazy and I do appreciate the help.
(3,254 Views)
