Unable to resolve conflict in project dependencies
I have a, what appears to be, an empty vi but as soon as I put it in a project a conflict appears in the dependencies. It is a LabVIEW 2010 vi which I added to this post. So when you create a new and empty LabVIEW 2010 project, add this vi to the project you should see this conflict in the dependencies. Any idea how to resolve this?
I added this vi also to a labVIEW 2015 project but when I save the vi the dependency disappears so there is a difference in behaviour.
(5,726 Views)
Hi Steffan,
what happens when you right-click the Vi in your project and choose "Resolve conflicts"?
Which conflicts are shown?
(5,717 Views)
Thanks Gerd,
This is what I see:
When I select Find | Callers it refers to Test.vi but there is no code in this vi.
I addressed it as a conflict but I now realize that is a maybe confusing. It is not a conflict but a missing vi.
(5,710 Views)
Hi Steffan,
a conflict usually occurs when a VI is referenced in two different places (as file on your harddrive).
A conflict in the dependencies usually doesn't harm…
Edit:
When I put your VI in a fresh project (LV2014) I also see this depency in the project. It seems your VI is "kind of broken" as it seems to reference a missing "DAQ_..." VI which doesn't exist on my harddrive apparently.
Solution: Delete this "Test.VI" and create a new clean VI!
(5,704 Views)
In my case it does harm Smiley Frustrated. I filtered this example from a large project. This large project contains a Source Distribution. One of the "Always Included" vi's (which of course is not empty) contains such a dependency that I cannot solve and LabVIEW returns an error during the build. So I need to resolve it but I don't no how...
(5,693 Views)
Accepted by Steffan.W
Hi Steffan,
recreate that "kind of broken" aka "insane" VI from scratch…
(5,660 Views)
Yes, it looks like this vi is kinda corrupt. It consists of a sub vi that is not visible on the diagram or something like that.
Creating it from scratch will solve this issue I guess. Thanks!
(5,650 Views)
