Unable to run the Multirecord Acquisition (NI PXIe 5170R/5171R) code on FPGA
I am unable to run the  'Multirecord Acquisition (NI PXIe 5170R/5171R)' from the example section. I am using a NI PXIe-1082 chassis with a PXIe-5170R oscilloscope module , after running the code there seems to be some issue with the 'DataClock' which is being used in the single cycle timed loop . I get the attached error message on compiling the code on the FPGA.  I guess I am missing on some settings to be configured. Any help on this would be highly appreciated .
Thanks.
Regards
(3,548 Views)
Hi Harss,
without having seen the details of your system, two ideas come to my mind:
- did you choose the correct version of the card: 4 vs 8 channels?
- have you tried recompiling the FPGA VI?
Cheers, Niko
Niko NR
Systems Engineer, National Instruments
(3,476 Views)
