Unable to verify Labview community edition
I've installed "LabVIEW2023Q3Patch5Community.dmg".
I am running an Apple M1 Ultra, with Sonoma 14.6.1
When I go to register/authenticate the software - I get the following messages:
"You have been authenticated.  You may close this window"
Then on the application it states:
"Unable to verify LabVIEW Community Edition entitlement.
Please login to ni.com and redownload LabVIEW Community Edition."
I have removed and downloaded 3 times - each with the same result.
Any thoughts or recommendations?
(1,170 Views)
Hi dalkeja,
I had similar issues with an older Mac.
Additionally I was not getting to the "You have been authenticated. You may close this window" with every activation attempt, only every xth time...
So I could not activate LV 2023 Q3 but managed to activate LVCE Q1 just now after going through the following steps:
  1. downloading LVCE 2023 Q1 instead of Q3
  2. attempting uninstall with the uninstall script of the Q3 dmg.
  3. manually removed all files/directories mentioned in the uninstall script, after I realised that the script ran through too quickly without removing the files
  4. Installed LVCE 2023 Q1, for some reason the default config did not install LVCE and I had to run the installer a second time explicily selecting to install LVCE not just the LV runtime
For now I cannot tell which part was actually causing problems and if all steps are really necessary to succeed:
  • There may be an issue with activating with LVCE Q3 for macOS:
    https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000ww6wCAA&l=it-IT:
    "if you have similar issues by activating LabVIEW 2023 Q3 on MAC download an earlier version (LabVIEW 2023 Q1 preferably) which will trigger the activation process."
  • The uninstall script does not seem to uninstall properly all files of a particular LV version or even all shared NI files in neither  /Library nor ~/Library. (To be considered also: multi user scenarios.).
  • Per default, the installer does not seem to install (or re-install) all files when not choosing "Install Type: Customise".
I hope this helps 😉
(1,109 Views)
Hi toffu,
May I ask where you downloaded and installed LabVIEW Community Edition 2023 Q1? When I checked the Community Edition page, it only listed the 2023 Q3 version.
I did find the 2023 Q1 version on the general LabVIEW download page, but I assumed it wasn’t the free Community Edition. Thanks!
(653 Views)
